5070ti Vs used 4080
30 Jan 2005
Inverness
Which would you choose?
They are pretty comparible price and performance wise from what I've seen I'm struggling to decide which to buy if any to finish cyberpunk with @ 1440p with path tracing.
The 4080 seems to go finish slightly above the 5070ti in a lot of benches and they seem to be around £100 less than a 5070ti on the used market. That's the similarity.
Where are you buying from?
If you could get a 4080 for a good price from say, OCUK MM where the prior owner would help with existing warranty? I'd go for the 4080, I've seen a couple go for around the £600-700 mark.
I do not rate MFG at all, and the better parts of the newest DLSS iteration will work on the 4080 anyway.
I'd rather wee blood than buy a 5070ti, it's a shockingly bad card even at MSRP.
Don't forget physx
Good point.
32bit PhysX is a no go in the 5000 series.
You're buying into a worse experience for older games, a potentially better experience for new games.
Space Marine 2 is a grand example, the 5090 is much weaker than the 4090 at 1080P, aka the esports res.
It's a laughable launch and should not be entertained.
Don't forget physx
Good point.
I can't believe people are actually working around this by grabbing some old GPU just to use it as a dedicated PhysX card — what a joke. This whole situation feels like a step backward.
