5070ti Zotac SFF
18 Oct 2002
Manchester
My case only supports 315mm length cards, and up until now it has sufficed.
I am leaning towards simply buying a new case but how “bad” would some of the zotac 5070 options be? The ones that are 303mm long.
They have smaller coolers, so presumably will be hotter, louder, but noticeably?
I guess for the cost of a new case vs a new graphics card it probably doesn’t make sense to limit myself to the smaller cards, but just curious how much worse the cooling would actually be.
Still a chunky three fan card, it isn't that bad.
Sapphire's 9070 non-XT Pulse is a small card too, by the way, though not in the 5070 Ti's class of performance.
Cheers! I think I might just grab a Meshify 3 and have the choice to go 9070XT or 5070ti, I had a 7900XTX which died on me recently and my 5700XT isn’t cutting it :)
