- 28 May 2007
What was the process in thinking when you got this system. 5090 it is with a 14700k but now am skint so let's get some cheap stuff and hope it goes well.
I was joking a little but Ram as well. Intel chips do well with fast memory. I just think you went a bit top heavy with a 5090 looking at the rest of the spec. I am a believer in having a balanced system when first built. If I am going 5090 my PC is going to have an x3d chip, fast Ram, great cooling, best m.2. No point in blazing over 2k if you don't back it up with top level components all around.I built the pc over a year ago. It’s a GPU upgrade not a full build. What cheap stuff are you talking about? Apart form the motherboard which is a Gigabyte b760 Gaming x ax, nothing was cheap.
Yeah PCIE speed ain't gonna make up 20% perf loss, 1-3% maybe but not 20%
what GPU did you upgrade from? Was there any issues when you were using the previous GPU?
No, there's no meaningful impact on a 5090, certainly not anything like what you have reported. I don't think your motherboard shares any GPU lanes anyway, for 13th-14th gen that's mainly Z boards with PCI-E 5.0 M.2 slots.Ive read that on some boards using extra ssd’s can cut the lanes on top slot in half. My 7800 xt definitely wasn’t affected but just wondering if Maybe it’s affecting this one?
Yeah I was hoping to avoid doing it but I think Ill try that next.That the benchmark scores are fine while games aren't suggests to me we're in the realm of "Windows Wankery". I'd echo the suggestion on the last page of trying the card on a fresh Windows install.
YesAre all these games launched via Steam by any chance?
Yes
It’s dead simple just press windows key and type ‘reset’ and select ‘Reset this PC’ then just use the download option. It even reinstalls basic drivers but if missing anything then just grab them from motherboard website and off you go.Yeah I was hoping to avoid doing it but I think Ill try that next.
Yes
Gigabyte
If you want to do a full back to square one reinstall, then you can do it via a USB stick and delete all your old partitions and go again. Mine gets funky using the front USB sockets so plug it into the rear ones to save you potentially having that problem.
If you have it installed uninstall Gigabyte Control Centre - sadly required to do some things but it is a buggy, bloated, telemetry loaded, POS which I've found significantly reducing performance in games before (for example on some setups games like Hogwarts Legacy take a 20% hit having it running), I'd also disable/uninstall any RGB software and if running disable the nVidia App overlay as with certain things running like filters it will reduce performance or conflict with other things reducing performance.
Did you try the steam shader cache first to see if it helped?Ok thanks, I wasnt aware of the PC reset, I’ll give that a go as it was the usb method and the hassle of having to remove the gpu to get to and remove the other ssd’s, and also trying to bypass the microsoft account again putting me off.
I uninstalled GCC quite soon after building the pc, I can’t remember what but it was causing some sort of issue so I got rid of it. I don’t have any RGB software either. The last bit of 3rd party software I downloaded was for some headphones and that caused some issues so I’ve tried to avoid anything that I don’t need since.
I’ve got faster RAM coming and I’ll do a windows reset, hopefully that fixes it. Won’t hold my breath though.
