50hz tv > 60hz signal ?
25 Jun 2004
in the clouds
my freind wants to buy a jap neogeo and a jap pc engine, the thing is he only has a 50hz tv. What are his options to get this to work?
Will he be able to run them through a coaxial cable instead of a scart as Ive heard that a coaxial cable only does 50hz?
Who said coax can only carry 50hz?
Coaxial cables can reliably carry a 1Ghz signal over a decent length.
Agreed.
I haven't had a TV that couldn't handle 60Hz since the late 1980s - and that one was a few years old.
If he is going to be using a coaxial (RF) connection, then the outputted signal will be NTSC not PAL, and will result in a black and white picture unless the TV supports NTSC. Plenty of modern TVs do, but you can buy a NTSC-PAL colour converter. But, to be honest, if you want the best from these retro consoles, a nice CRT TV and an RGB scart lead is the way to go.
Bigpops said:
Agreed.
hes got a 1980's tv, and it has no scart connection, can a 60hz signal go into his tv through coax?
The refresh rate isn't the main problem. It's the NTSC encoding which I imagine his TV will not support.
Just get a cheap TV for playing his stuff.
