50mm on 1100d
19 May 2004
Just bought the 50mm 1.8 for the girlfriends canon 1100d and got a birthday BBQ tomorrow so was wondering what the best settings may be given the weather we're having if she goes in manual mode
ISO200 at 2.8 may be too high which will go beyond the 1100D's fastest shutter speed of 1/4000s in this kind of sunshine. Stick to ISO100. It doesn't sound like she knows manual mode so as above, use AV mode.
There are no best settings. I wish people would stop asking this.
I'm not forcing anyone to reply. Surely given the expected weather and outdoor setting then there are better settings than others ie shutter speed, f stop and such.
I am merely asking ppl with a far better knowledge of this than my girlfriend has so she can have some good photos to look at in future
There are no best settings as JB said. Some people don't like shallow depth of field so will use smaller apertures and varying shutter speeds for what they are trying to capture. In AV mode you're only choosing the aperture so everything else is done by the camera. There are no golden settings here :p
Simply put, use the light meter in the viewfinder, if the marker isn't in the middle then your exposure is going to be off.
f8 and be there, done
I don't think you really realise the complexity though....
I expect tomorrow will be beautiful sunshine? If that's the case, then you have some interesting issues even if you stick the camera on AV mode at f8 and let it do the rest. Hell, even on full auto it's going to struggle. You know why? Because beautiful sunshine is horrific to shoot in often.
Shoot with the sun facing the people? Pretty solid lighting on the subject, faces well lit, camera will (probably) correctly expose. Sounds good? Yeah, until you realise that everyone in your shot is unfortunately squinting because the sun is in people's face...
Shoot with the sun behind people? Well, now people aren't squinting, much better faces. But now, the camera is probably going to expose for the scene, and there will be shadows cast across the people's faces. You have two options going forward, either stick in some compensating exposure. Faces are now correctly exposed, but your background is going to probably be significantly overexposed, which given the question, I suspect you wouldn't necessarily know how to correct in LR (especially as I'm thinking you won't be shooting in RAW). This leaves the option to use a flash as a fill flash for the faces. This sounds great, but I suspect given the power of the flash on the 1100d, it's not really going to be able to work fantastically in the level of sunlight we have at the moment. Even if it does fire and correctly light up the faces you have the final issue of the flash probably causing a bit too much harshness in terms of lighting. This can be vastly unflattering.
I had great fun trying to shoot in the same situation over the past week. It's taught me a lot about what I can and can't get away with, and plenty of the shots aren't as good as I'd like because of it.
If she wants to delve into manual mode then the best way to learn is to do. You need a rough understanding of App/Shutterspeed/ISO etc... But once you do, just go out and practice, at events exactly like this BBQ! IT will teach her so much. Thankfully we're in digital, so if she tries to take a picture of someone, looks at it, and it doesn't work, she can dial in adjusted settings and see how it turns out.
What's more, the best thing about the Nifty Fifty is that it can do wide apertures at a budget price. This is fantastic for creating gorgeous depth of field, but to do so, you need to shoot at these wider appertures. There's little point turning up with a prime lens and shooting at f8. You can do that on your zoom that has much more versatility for getting shots, and lots less footwork needed.
The best advice I can give mind given the short time period, is ISO 100, F2.8, AV. Good luck.
kd
I took some great shots of the nephew in the park, some great ones especially in the swings, the nifty fifty surprised me how accurate it was on focusing moving kids.
Experiment, but as indicated above, you can get some really nice depth of field effects at wider (lower number) apertures. Go for AV experiment and get close to your subject :)
I personally wouldn't shoot everything at f2.8, the lens is a cracker and pin sharp at f5.6 or so. Please don't be dragged into the old trap of 'zomg it will do f2.8' so everything must be at f2.8.
I personally wouldn't shoot everything at f2.8, the lens is a cracker and pin sharp at 55 or so. Please don't be dragged into the old trap of 'zomg it will do f2.8' so everything must be at f2.8.
For my money it's pin sharp at f2.8 as well and if your going to shoot at f5.5 etc purely for sharpness you might as well stick with the kit zoom as it too is pretty much pin sharp at f5.5 and has IS as well.
For me the key is selecting the right aperture for what your trying to achieve which might not be the sharpest!
Everything wide open! Unless it's a group shot but otherwise let that light in :)
