50mm w/tele
30 Sep 2005
Hi people,
I'm considering buying the 85mm 1.8 and the Canon 1.4x Teleconverter
Now, my question is, should I sell the 50mm 1.8 mkII I currently have, buy the 50mm F1.4 and use the teleconverter to get a similar focal length with the teleconverter rather than buy the 85MM 1.8?
As Joe T has already mentioned the the 1.4x only works with a limited number of lenses
Buy the flash m8, well worth the money :) as the 70-200 is a great lens .
Phoenix_Cosmos said:
Oh yeah dont waste money on a Teleconverter. Get the flash (everyone needs a flash)
Well fine, but i need the teleconverter for a bit more reach on the 70-200, the intention with the 85mm was to take low light shots, but I guess I could try it with the flash and 70-200 if that's the best bet
the 85mm is a fantastic lens as ive said before, i dont think a flash can replace it, or vice versa, kinda something you need both :p
The 70-200 F4 with a 1.4tc will be f5.6 constant, thats.....pretty bad, and focusing will be pretty slow too :o
Tom.
