55" and 40" TV Wall mount bracket recommendations please
4 Mar 2003
Chatteris
Within the next month I expect to be making my 55" TV purchase. The Sony XE9005 is looking favourity (it stock remains) although I am watching the LG B7/C7 - however I don't expect those to drop price any further, what with them already being £1k less than launch, I expect they will just go out of stock.
So, I am looking for recommendations for wall mounts for two TV's. Requirements being they are easy to install (as I've never done wall mounting before) and they sit as flush to the wall as possible but allow me to install some surface mounted trunking to hide cables (which will finish behind the TV for neatness).
A. Mount for either Sony 55XE9005 or the 55" LG B7/C7 - Assuming they would all fit on the same mount
B. Mount for 40" Samsung UE40ES6900 - Current main TV moving to a different room.
I can see 101 different wall mounts but I've got no idea if any brand is any better than the other, if any are easier to install etc.
Cheers.
I've got this and it's robust and (relatively) easy to fit. Sits pretty close to the wall but I'm sure ones with less features may be tighter on the wall.
https://www.amazon.co.uk/gp/aw/d/B0...Wall+mount&dpPl=1&dpID=51l9iwoHXOL&ref=plSrch
(it was £30 when I bought it in May last year :o)
I've also used a smaller one from them in the kitchen and similarly seems robust.
Thank you for that. I'll confirm the VESA size of the old TV, but I'm sure that would work for that one too.
I just didn't even have a starting point with regards mounts - didn't want to get something in and then to find it was "the one that always falls off the wall" :)
