550D advice please
30 Dec 2010
Over here
Good evening,
I have the fore mentioned case and an h100i. I was going to do a push/pull on the h100i mounted at the top but after reading I think I'll be best off just doing a pull and I can use my other two fans elsewhere.
The fan options are:
2 front - 120mm
2 bottom (not using)
2 top (taken by h100i)
2 side 120/140
1 rear 120/140
Now my idea was this:
TOP Intake- Taken by h100i using 2x SP120 fans
Front Intake- Use the 2x SP120 fans I have spare from no push/pull on h100i
Side Exhaust- 2x 140mm AF140 (7990 will kick out a fair bit of heat)
Rear Exhaust - 1x 140mm AF140.
I'm new to effective cooling but if I've made a howler here let me know or any better setups.
Thank you kindly
