5570 cooler
29 Aug 2010
United Kingdom
Hi peeps,
Just wanted to know if there are any 5570 low profile passive graphics coolers I could bolt onto my sapphire card, its a touch noisy for my likes, if there aren't any is it a good idea unplugging the fan as its only a tiny little 30/40mm fan and can't be doing that much for the card?
Don't take the fan off!
You can always manually set the speed for the gpu fan to make it less noisy.
+1
use msi afterburner to regulate and watch your temps, fan speed etc...
i wouldn't bother getting a £22 cooler for a card like like... you could buy that card for that price.
yea msi afterburner will let you choose whatever speed you want whether it be 10% or always 100%, auto settings will let MSI:AB do it for you which is the best way you can do it
