55H6400 OR 55JU6400??
10 Apr 2007
Cannock
OK so I'm on the lookout for a 55" TV, and I'm looking at the above 2 models.
I hear that bang for buck, the H6400 is an fantastic TV, but it's not 4K. From what I can tell, the JU unit is the same TV but with 4K?
I doubt I will use the 4K content much. I was wondering if the 4K resolution though would make a SD TV picture worse than the H6400?
If anyone has any advice that would be great, the JU unit seems to retail only £100 more than the H currently.
4k tv's that are cheap are best avoiding if you value picture quality.
if your the type of person though that has to ask then you probably wouldn't be able to tell the difference between a premium panel and a crap one so go knock yourself out with the 4k one.
sometimes ignorance is bliss as the uninformed can buy tv's for £300 out of tesco which are 50" and think they are amazing.
whereas all I can see are the faults and have to have a premium highly recommended panel from hdtvtest or avforums
