5600X cooling solution
28 Jan 2011
After some very helpful advice on cpu‘s on OCUK I think I’m going 5600 / 5600x for my new cpu. Just wondering if I can save a few quid and use the included cooler?
will this do the job ok? No Overclocking etc will be done.
I used the same cooler on a 3100 for about two days before i ordered a 34 esports duo, while they work then are also whiney and annoying but see how you get on.
Wraith prism on a 5600x under load (Handbrake/Cinebench), temps about mid/upper 60's in a 4000D airflow, thats what I got on my nephews rig when I built it in the summer.
I left the stock cooler on a 5600x build for a friend and it surprised me. Case wasn't incredible, the front panel was solid with little air vents. Still stayed below 70C under load. 80C with PBO going at ~5ghz on all cores
