560ti palit problems
PGB
PGB
10 Oct 2011
I got a gaming pc a few weeks ago and everything is working fine exept for my 560ti palit, this thing seems more like a jet engine than a gpu and i've been getting texture popping issues and generally a poor visual experience. I still see jagged edges even with AA and sometimes when turning sharply a line will appear for a split second. Is this a common problem on most 560ti palits or is it just a faulty card?
Need a bit more information than that please to help.
What is the spec of the PC, including case?
Have you O/Cd the GPU in anyway ?
What is the idle temp of the GPU ??
What game are you playing and with what settings (screen res etc) ?
Ive had Palit cards in the past and they have been very good value for money, plus have performed well.
sorry, here are my specs
CPU: AMD phenom II 970
Motherboard: m5a99x EVO
cooler: ECO coolit A.L.C
Ram: 4gb kingston hyperX
I dont know the idle temp but it gets pretty hot playing games though, the fans are always on 100%
I'm playing at 1920x1080, and im currently playing Dues ex HR, AlterIW, Cs:s, BF3 beta. I have not o/c'd the gpu. also lowering resolution doesnt make much diffrence.
I suggest you download MSI Afterburner. Not because you want to O/C your GPU, its so you can see what you idle and your max temperatures are.
http://event.msi.com/vga/afterburner/download.htm
The above link will help you to download the software that is needed. Install it and have it running whilst you play your desired game.
I would then report back with your idle temps and max temps :)
Just a quick update. I got a replacement card from PCS and the noise and overheating problem seems to be resloved. However there is still texture popping. Is there any possible fix for this?
