Permabanned
- 10 Nov 2005
So basically when I built the rig I tried both methods of undervolting by adjusting the mv and then trying the PBO2 undervolt method... And it literally made ZERO difference in power consumption/temps and ran the same at the wall monitoring it with a plug metre and the same in hwinfo (or whatever it's called)... Nor did the actual core voltage run less than stock whilst monitoring it
The only difference is when I did the PBO2 method I was able to boost at a higher than stock ghz and obviously then my power draw was even more than stock...
What am I doing wrong? Or am I just unlucky?
For reference I used this method first:
And when that did nothing I tried this the PBO2 method:
