5770 Crossfire Power Usage
27 Feb 2006
Normanton
I was thinking about getting another 5770 to go in cross fire with my current setup but im not sure if my PSU will hack it.
I've been on the Antec PSU calculator and it says my current spec will only draw 388W
and if I change this to cross fire it says the max draw will be 436W which in theory will work with my OCZ Modsream 450W PSU but is this pushing it too far? It does have a spare PCIEx power conntector on it though indicating in can support 2 cards
Current spec is
Q6600 @ 3.75Ghz @ 1.5v
4 x 1GB OCZ DDR800 @ 830mhz @2.1v
Asus 5770 @ 1Ghz, 1.35ghz @ 1.25v
Asus P5E
Samsung 64GB SSD
DVD-RW
Fan Controller
3x 120mm normal fans
1x 250mm fan
2 USB devices
Laing DDC water pump
Well I have the following running on an Antec HE 550W:
Q6600 @ 3.4GHz
Intel DX38BT motherboard
8GB Corsair PC10666 DDR3 (4x2GB)
2x Ssapphire 5770's (960/1350)
1x POV 9800GT 512MB
6x 320GB Seagate Barracuda's
2x Pioneer DVD-RW's
2x OCZ Throttle eSATA 16GB flash drives
Alphacool front display panel
These can be very misleading
1 options it to buy 1 of those cheapo wattage monitors, quick search found kill-o-watt meter. Can't link obviously. This will show you your overall power draw. deduct what you know the 5770 draws and double it. add it back on. Is it more than 450w?
It's not really the wattage I'd be concearned about, seems as though it could handle it wattage terms. It's wether it has enough amps on the 12v rail.
Also,
Energy consumption
We'll now show you some tests we have done on overall power consumption of the PC. Looking at it from a performance versus wattage point of view, the power consumption is good for a product of this caliber, according to ATI the 5770 has a TDP of 108 Watts.
Our test system is a power hungry Core i7 965 / X58 based and overclocked to 3.75 GHz. Next to that we have energy saving functions disabled for this motherboard and processor (to ensure consistent benchmark results)......
Single GPU 5770
* System in IDLE = 228 Watts
* System with GPU in FULL Stress = 321 Watts
* Difference (GPU load) = 93 Watt
Dual GPU 5770
* System in IDLE = 249 Watts (= 21W added over single GPU)
* System with GPU in FULL Stress = 423Watts
* Difference (GPU load) = 174 Watt
Source: http://www.guru3d.com/article/radeon-hd-5770-review-test/11
I wouldn't want to run my psu 100% flat out, I'd be more inclined to give it a bit of headroom, how old is your psu, I'm sure they degrade over time slightly.
it is a couple of years old now and touch wood never had any problems with it.
I might get another card and try it any signs of instability/crashing I will have to upgrade!
