- 12 Oct 2012
- London
I have a Gtx 580 Rog but for some reason reason every attempt to overclock it ends in failure Currently The Clocks are stock
Engine Clock-816 MHz
Memory Clock-4008
I Tried to push the Engine Clock Up to 850 MHz and it BSOD I then tried 830 and still it BSOD, I upped the Voltage and same result. Its not temperature related as i have never seen this card get over 60 Degrees due to my Fan Curve and the Cold room that im sitting in... Is this normal for this card or do i have a Reaaaly Bad Overclocker
Oh Its Plugged into a 850w Corsair Power supply so im positive power isn't the issue here
I've Been using MSI Afterburner to overclock also
Thanks!
Memory Clock-4008
Thanks!
so yours will still be slightly quicker...
