5800X Cinebench score lowers with PBO enabled
5 Aug 2006
Derbyshire
Hey all.
My 5800X gets around 5800-5900 on Cinebench R20 multicore.
With PBO enabled (BIOS or AMD Ryzen Master) it lowers to around 5500.
My motherboard is decent for a B450.
I have a water cooling loop, albeit an entry level one.
I tried the Ryzen Master curve editor in the BIOS and I get similar results as with PBO enabled.
My CPU does run very hot and can often hit 90 degrees Celsius.
Any ideas on what could be going wrong?
I've had a good read on here and on other forums without luck.
Hey all.
Try setting manual PPT 127 TDC 88 EDC 125 then a curve optimiser negative -15 all cores.
Get about 5800-5900 with everything at stock and PBO off - just tried with PBO auto and got 6045 which is better than any of my prev PBO auto tests. Hit 84.4C max with a NH D15 air cooler. One thing I will say is that I wait after a reboot until the CPU is actually idle (for me <40C temps) to run the cinebench test. Normally takes a minute or two waiting on desktop for windows to finish doing its launch stuff.
What is your cooling loop, exactly? Is the pump running at full speed, and are the radiator fans working correctly, with adequate airflow?
That's a hot chip...
Tried reseating the cooler?
It is indeed a hot chip.
I have not tried reseating the cooler, but I may need to clean up and re-apply the thermal paste.
The loop is a 2x120mm rad -> CPU -> 1080Ti.
The fans never go above 50% speed, but my overclocked 1080Ti pumps out way more heat when gaming so this should not be a problem.
The pump speed I can definitely increase.
It is one rad, but has 2x120mm fans :).
It is an end of line aluminium water cooling kit. I can't upgrade the radiator, but if I cannot overclock the 5800X I am not too worried!
Yeah it's asking a lot for just 1 240mm rad, how's temps while gaming when you have the 1080ti adding some heat?
