5800X PBO curve optimiser help please
7 Dec 2002
Frauenfeld, Switzerland
Hi guys. I have read a lot about PBO and undervolting using curve optimiser for my 5800X but I have hit a wall and wanted some advice.
Basically I mainly use my PC for gaming and wanted 2 things:
- to eke out a few more FPS in CPU limited games like Microsoft Flight Simulator 2020 (especially the minimum framerate and 1% lows).
- to reduce my temperatures since I have a relatively small form factor case.
I tested different power limits with PPT, TDC and EDC and found that the following settings gave me the best thermals with my case and cooling: PPT 110W, TDC 75A, EDC 100A. The efficiency of the 5800X drops off a cliff after 105W and by tuning these values all 3 are hitting 100% together in HWiNFO64 which apparently suggests that they are balanced. I dropped my temps in Cinebench and gaming benchmarks by about 5-15c depending upon the workload whilst keeping my scores within 5% of stock.
I then tried curve optimiser and went progressively from -10 to -30 all cores which was stable in the OCCT single thread testing using the following recommended settings for stability: Data Set - Large; Mode - Extreme; Load Type - Variable; Start at cycle - 1; Threads - Advanced; Physical Cores - core #0; Virtual cores - Physical only; Core Cycle - every 5 sec; swap active/inactive cores - disabled. I got no errors in the log down the bottom left (I assume this is where they should appear?).
I then bumped PBO boost override up to 50mHz then 100mHZ with the same -30 and still got no errors in OCCT V10.1.5 but I started getting frequent BSOD crashes in Destiny 2. I dropped curve optimiser down progressively to -10 but still had crashes so I disabled the PBO boost override and now my system is stable after several 4 hour gaming sessions.
So to where I need help: I was led to believe that this setup on OCCT should have identified which cores would crash and allow me to set the curve optimiser individually so my best cores have a lower negative offset (-5 for example) with a larger offset (-15 to -20 maybe) on the weaker cores which won't be boosting so high. But since it never found errors (or I am not looking in the right place for them) I just kept pushing further. So should I try Core Cycler instead or some good old Prime95 testing?
I realise it is perhaps unrealistic to both reduce voltage on the curve optimiser (technically increase frequency at a given voltage) and set power limits and also expect to increase my boost clocks with an offset. But it seemed like lots of people on different forums were managing this since the 5800X is more efficient at lower voltages and power and by limiting the voltage sent to weaker cores with individual curve optimisation you could save more energy for the best cores. This together would allow higher boosting since there is less heat. Is it even worth trying to set a boost override on the 5800X for gaming or just try to go further again with the core offsets to improve efficiency further and allow higher sustained boosting? I gain score in benchmarks with the extra 100mHz but not many fps.
Sorry for the length of my post. I appreciate any help you can offer. My RAM is on the default XMP settings since tuning it last year just led to system crashes and at best 1% performance boost over XMP. All voltages are set to auto on the latest BIOS for the X570 Tomahawk. My case fans are all Noctuas with a fairly agressive curve to keep CPU temps around 70-80c and my cooler is the Noctua NH-U9S with 2 fans. Thank you in advance
Silicon lottery. Just because people "say" they have X or Y settings and it is 100% amazeballs does not mean it is true or that your chip will achieve the same results. You have obviously done your research and understand this better than I do so you can see where the problem may lie, maybe your chip cannot run those clocks at lower Voltages? I need to find the time to do PBO on this system so will be blatantly stealing any tips and knowledge you and others post in this thread to help me out.
When I was testing my backup PC I was using Prime95 for stability tests. Worker threads would stop and that would tell me I had problems , that is much better than a system crash to show a problem. If you use Prime95 for your testing the individual worker threads stopping working may show you which cores are crashing and help you identify which ones need more voltage. It stresses all cores equally so could be a good tool for diagnosise.
There was a big 5800 PBO thread on here with loads of detail in it but I cant find it now.
Have a look at this
https://forums.overclockers.co.uk/t...ow-to-configure-pbo-curve-optimizer.18920081/
Thanks man, that thread is pretty helpful. I did do a search here but not far enough back. I will try to see if anyone in there can help as well.
Right now I am running Core Cycler fixed at -10 on my best 2 (from Ryzen Master) with -20 on my other cores. Will test in games if stable
PBO for me has been a nightmare to try and tweak.
The PPT TDC and EDC values have a big impact on multi-core and single threaded performance and you reach a point where you need to compromise.
TDC has the biggest impact on multi-core. But setting TDC high will impact how high your cores can boost to.
If your main use is gaming I'd focus on EDC. I personally found that running at around 130 EDC got me the best single core performance.
All three settings PPT, TDC and EDC interact with eachother though, so let's say ypou were tweaking TDc for multicore, certain settings on EDC can hamper it too. There's a lot of tweaking, experimenting and testing.
The curve optimiser pretty much helps increase how high individual cores can boost to. My second chiplet cores tend to boost to just under 4.9ghz at stock, I set them all to -20 and they boost to 5.0ghz.
One thing I have realised is deopending on your usage, any overclock bring minimal real world performance gains short of benchmark results.
Just to close off this thread, I got all my cores tuned in at the settings above (110W, TDC 75A, EDC 100A) with a +50Mhz PBO boost override, -10 offset on best 2 cores and -20 on the others. Gained performance in single and multicore Cinebench vs stock and vs PBO auto whilst also running cooler. I ran CoreCycler over several nights and got no further errors. All my games and Windows have been stable without crashes or Windows errors logged.
Now I just bought a 5900X on sale (will be better for my brother when I pass this PC on to him for his video editing work) so will start the process over again but with higher power targets (PPT 145W, TDC 95A, EDC 130A) :cry:
