5800x temps question
17 Mar 2018
Im running a R7 5800x on Aorus x570 Elite and the Aorus liquid AIO 360.
As a new owner of this kind of CPU I was surprised to see some extremely high temps on desktop (while installing a game for instance it sits on 60-65c)
I tried some quick gaming just to test it and I had 68-75c ups and downs on RDR2 Ultra settings. (Which it seems okay I think?)
Now after some research online I realised that many people have the same temps "issue" with this CPU and they all advice some minor undervolting
What's the opinion on that please? Can I get a small undervolt without losing noticeable performance, but Cooling my cpu down a bit?
If yes, can I please get some information on how to do it on this motherboard?
Regards
Would you have any advice on undervolting? Right now as we speak I'm installing Cyberpunk and everything is on idle literally everything and its stable on 73c. Isn't that bad ?
Try setting PPT 127 TDC 88 EDC 125 then curve optimiser negative 5~10~15 etc however much you can go while remaining stable.
Tbh though 73 isn't bad especially if you have a high power GPU that dumps out a lot of heat into the case.
Isn't bad on desktop while only downloading a game?? gpu is dead while this happens. I'm not talking about gaming. I'm talking about desktop
Also that stuff seems like Chinese to me :D but I'll try to figure it out thank you !!
I found these settings in PBO which was disabled. I enabled it and set those 3 as you said. I found the Curve optimiser too should I choose all cores or Per core??
Figured it out these settings did not help , but I managed to find the exact undervolt (1.25) that gives me exactly same if not better performance, with 30c less .. im shocked. Thanks for your help
