5800X3D Upgrade to 7800X3D
9 May 2022
northumberland
So recently bought a 4090 phantom from overclockers I currently have a 5800X3D is it worth the cost to upgrade to a 7800X3D at 2560x1440/3440x1440 resolution
You tell me
CPU+MB+RAM would be getting to 1000
Sure, you get 17% more fps, but if in the already high range say from 150 to 175, does it matter?
I suspect overall you be hard to tell the difference actually playing
its a hobby so you tell us
Benefit is next year for an upgrade again.
'Worth' is subjective. What you should look at is whether or not the 5800X3D is already getting enough FPS in the games you play (where you're not GPU bound) in order to hit your monitor's refresh rate cap.
As above factor in DDR5, a new motherboard, the CPU and what you might get for the 5800x3d/Motherboard/DDR4 for some (or many) the difference is a lot of money for not much improvement.
