5820k CPU power states help
Caporegime
20 May 2007
Surrey
Hi Chaps,
*long boring post incoming!
I purchased the X99 5820k Black Friday bundle a little while a go and was using the 3000mhz ram and 4.1ghz overclock for a bit all fine.
However I decided that for my music production work 32GB would be better really and found a good deal on a 2400mhz 32gb (4x8) kit so have replaced the ram ( I went for lower frequency ram for stability as 32gb at 3000mhz and an overclock might be troublesome and I cant see the 600mhz making a massive difference to things especially when the 2400mhz kit's timings are tighter).
Anyway, played around a bit today and all seems stable at 4.3ghz at 1.2v ( which is pretty I good I thought) with ram at 2400mhz - Have done several loops of Realbench's benchmark and a 30 minute Realbench stress test. Max temp seem to be 67 on the hottest core (~63 on the rest). I don't have any real need to go higher so I am happy with that. I realise it might not be 100% stable without more testing but it must be in the ballpark so will leave it and tune as I go if I experience any problems.
Anyway, I have one issue which I am not sure what to do about and it relates to the cpu's power states. Basically I noticed my image editing score was way off on the realbench benchmark (lower than what it should be and lower than when I had the 3000mhz ram using 8pack's settings). I noticed that during this test the cores weren't always maxing out at 4.3ghz as the cpu usage isn't constant. In the video encoding test the score is fine and all the cores get loaded at 100% and therefore boost to 4.3ghz.
The fix I found was to set the windows power management mode to high performance. With this on all cores are constantly at 4.3ghz and the voltage is always at 1.2v. This gave me the score I expected in Realbench.
I guess I didn't have this problem on 8pack's settings as I wasn't changing the multiplier ( just the strap) so there wasn't such a large range for the multiplier to change through. Does that sound right?
However, I am not sure I want to run it at "full chat" all the time as it would be nice for it to downclock and lower the voltage at idle. I would turn it back but having seen the affect this has on the image editing in Realbench I am worried that having the power set to balanced to allow the cpu to change frequency is going to result in lost performance in some games and also in Cubase for my music production. It seems like if the task isn't taxing the cpu enough, it won't be boosting to the full 4.3ghz.
So essentially I wanted some advice on what you think I should do and also what you guys tend to do. Do you find having power saving modes on affects performance in certain applications and if so do you therefore have the voltage and frequency on full all the time? I mean maybe it is just an issue with how Realbench implements that image editing benchmark but I am really not sure. Also, I don't want the cpu to degrade and I am worried running 1.2v through it 24/7 all the time might cause issues.
Advice and experiences are most welcome! Thanks.
