Overclocked my 5820k to 4.6Ghz @ 1.22V, had it at 4.5 @ 1.2V for a few days with minimal effort of overclocking and decided to push for more as I knew this was 150% stable!
RealBench Heavy Multitasking score - 132810
RealBench H.264 Video Encoding score - 141060
RealBench Image Editing score - 111919
CineBench R15 - 1322
Only ran the tests once (bar the Cinebench which i ran 3 times as i got 1 high and 1 low and was curious which one it really was, turns out the high one was the right one, so something could have happened with the scores such as inconsistencies so bear that in mind, i will run them again if needs be.
Its being cooled by a 240mm AIO, temps are around 25-33 idle on all cores and under load most cores reaching between 62 and 71 with the core going to 71 being the hottest by about 3 degrees and it spikes between 68 and 71 quite quickly, but the fans on the rad haven't even kicked up at this point, so it will get cooler if it needs to so I dont think cooling is an issue.
