Hi guys, I have an Asus EAH5850 with voltage tweaking.
Over a fresh install of W7 64bit I popped on Asus's latest own catalyst driver then OSDgamer and then SmartDoctor.
Ive looped vantage a few times to check stability and base score, all looks good but Im struggling to get fallout 3 gotye to run at all.
After a good bit of investigation and many attempts to sort the random crashes I belive Asus's OSDgamer and SmartDoctor apps maybe causing the problem as people have documented this.
I'm not all to impressed with smartdoctor, although it looks like it does the trick it doesnt seem the most robust of apps.
I belive MSI's afterburner to be the preferred app for over volting these ati cards. I downloaded the latest version off MSI, once installed the instant I run the app it blue screens my system!
I was under the impression afterburner works very well with these Asus cards, could it be because I have still got Smartdoctor running
I hope there is someone out there that maybe able to help.
Im just looking for a method of voltage contol that will not cause games to crash out.
Cheers
Cheers
