Hi,
Recently bought a second 5850 so installed it into the 2nd PCI-E x16 slot (see sig for spec), booted into windows and CCC recognises crossfire and has it enabled. Problem is FPS are the same if not lower than one 5850!
The cards are both Sapphire, one with a reference design and the other with MW2 with central fan placement.
Temps are within normal limits, with the warmer card at 60C, and the cooler card at 50C idle and are not getting higher than 70C-80C in game (both hit 87 in furmark).
Example of FPS I'm getting:
BFBC2 x1 5850 between 50-80 fps, crossfire 40-60 fps
What gives?
Any help would be much appreciated as this is my first crossfire setup.
Thanks
What gives?
Thanks
