- 4 Feb 2009
Is anyone having screen flickering issues when using a dual screen setup? I have a samsung 37" 1080 tv on monitor 1 using a 1920 x 1080 resolution with a samsung syncmaster 204BW on a 1680 x 1050. The problem i'm having is the Syncmaster which is the main monitor, seems to flicker a lot and corrupts. I changed the monitor to see if it was the monitor but the other monitor did it too. Then I changed the DVI cable and it stopped for a day but it is doing it again although not as bad. The 1080 Tv however does not flicker at all. Anyone else having simillar problems?
