5870 - random extreamely low fps for a few seconds in games (driver issue?)
5 Apr 2008
Hi,
I got my 5870 with cat 9.12 beta drivers
Some games randomly for a few seconds go imensly low fps then really quick a few seconds later, making the game run too fast, then returning to normal.
Have you heard of this exact problem??
I have had no other problems. It did it in mw2 but 9.12 seemed to fix it. (could have been chance)
But it now does it in dirt 2. Does this mean that the 9.12 did not fix the problem for mw2? Or could the beta drivers just have helped on cod6?
I want to be sure it is a driver problem before voiding the warranty installng a gpu block. :)
I think win 7 starts from about 9-10 I believe, don't quote me, I m on vista 64bit
I m not upgrading to win7 till next year, on purpose ;)
Have you tried the DiRT2 hotfix (9.11) drivers? Reports have been very mixed concerning the 9.12 betas.
i have exact same issue with my 5870 911 drivers with dirt 2 hotfix installed
does this happen only on dirt 2?? It is quite reassuring to find another with the problem, indicates a driver issue. Appantely, many people get 5870s to work after reinstalling the os and making sure your reinstall isnt the rc windows 7.
Thanks
Tim
the only game i have noticed in other than dirt 2 is need for speed shift but does it less.
think i will wait for the 9.12's to arrive and if it still does it may try a os / driver fix, i don't fancy a win7 total re-install, i will try an older driver before going that far.
cod4mw2 is smooth as hell, as is every other game i recently bought inc borderlands.
and it does a slowdown to extreamely low fps for a few seconds yes?? Just want to be sure it is the same thing. Cod is fine now i put the 9.12 beta on but dirt 2 does it and funnily enough F@Home!
