- 20 Oct 2002
- London
Just a quicky - noticed that my refresh rate is at 59hz (see spec in sig). I have the option of 59 or 60 and was just wondering which i should be choosing? Thanks.
Darg said:Never seen 59 as an option before. Anything lower then 75 hurts my eyes.
Craig321 said:I'd say use the highest Hz you can on a LCD monitor.
I'm using 75Hz, so IIRC it'll only start ripping when my FPS go over 75 rather than 60.
Craig.
Darg said:Ripping can occur at any refresh rate or FPS. Basically its where the frame being drawn changes as the screen refreshes. The only way to eliminate it fully is by using v-sync.
Craig321 said:Oh, I thought ripping was when the games FPS goes over the Hz of the screen
jongeeone said:59hz is a windows bug/error afaik. It is 60hz
