5900x o.c. bios settings
13 Dec 2021
Corleone
Hi there.
I have the 5900x with Asus rog crosshair hero 8 wifi. Im using the typical o.c. profile, The curve optimized:
+100 override
-20 all core and -10 gold and silver core.
During the game i saw the core voltage is very high.. Around 1.480.
I know this is the best way, but i want to get a low voltage in different way, like ccx1 or ccx2 method.
Any suggest? This is my first Amd cpu... For me its another world...Im noob
Manual voltage and lower boost may be only way. Using curve optimization only goes so far before it becomes unstable for me.
So i used stock clocks and -15 on curve optimiser so boost is standard to 4.65ghz. then i just raised ppt from 65 to 95w and that makes the all core boost rise up. Max voltage i seen is 1.35v depending on load. Prime95 sees all cores around 4.2ghz and voltage is around 1.15v. raising ppt more than 95w gets more all core boost but my cooling cant handle the temps without more noise.
Give it a try various ways to go about it.
