5900X undervolting
22 Oct 2008
Lisburn
With the warmer weather, my office gets a bit toasty with the setup in sig. I'm looking to take the volts down a notch with the CPU to see if that helps with a bit of temp drop. I see people talking about negative offsetting but no clue where to start or what ROG settings to use. Anyone with a 5900x and a ROG mobo, that have undervolted, able to ping up a few settings I can try? This ROG bios is very detailed and there's so many settings and menus so I'm a bit clueless as to where to begin.
I use a 7900X and it is 170W TDP as standard, I have put into ECO mode (65W) and has helped with temps a lot and cant really notice much drop in performance.
Yeah same here pc room
Gets toasty got a 5950x and a bios so complicated
It has options I never heard of before
Other option I use is just lower the
Ppt,edc,tdc
Can even do that in ryzen master
And save it as a profile
Or test the settings in ryzen master first
Before applying to the bios
