Can anyone with a new Ryzen CPU please check their system log and report back if you are seeing any WHEA Logger Errors.
Specifically:
Reported by component: Processor Core
Error Source: Machine Check Exception
Error Type: Cache Hierarchy Error
Think the error ids are 18 and 19.
I was getting loads of them 20x a day. I'm running 64 GB of Corsair LPX 3600. I had to lower frequency in bios to 3200 which has stopped them from occouring. However I since had the pc restart/crash and could see another WHEA Logger error was the cause.
Iv scanned the net and it seems this could be a bios issue or a bad cpu. Fortunately I have 2 5950x systems and both exhibit the same issue so leaning toward bios.
Would like to know how how far spread the issue is. You may be getting the errors and not even know it.
System:
Asus x570i Mobo
5950x
3600 LPX Corsair Mem
corsair sf750
gtx 1080
Im on the latest asus beta bios.
Also my bios dosent recognise chassis 2 fan so runs at constant 100% (I can adjust it using software in Windows tho) Anyone else seeing this also? All my fans are pwm.
Specifically:
System:
Asus x570i Mobo
5950x
corsair sf750
gtx 1080
.Last AMD CPU i had was the FX chip i think Circa 2010.
