Hi 8pack I've already posted a thread but would like to hear an answer from you, it would set my mind at ease if it came from you.
Hi all
I bought the XSPC RayStorm D5 RX240 V3 WaterCooling Kit, and ive over clocked my 5960X to 4.6ghz with just over 1.250 and my cache at 4.6ghz with 1.35v fully stable. will try go further at a kater date as i think i have a decent chip for once!. My idle temps are around 30-38degrees. Under stress testing it goes to 73degrees. Would this be considered normal with my water cooling? or is something wrong?
I have my pump set to setting 3, and moving it to 5 makes little difference.
I have re seated the block twice, second time round with artic silver 5.
Just want to know if these temps should be normal with my cooling and wattage.
Update: Just been testing my games. Farcry 4 and GTA V maxed up. Looking like temps are stable around the high 50's, just a little more info for you.
Thanks in advance.
Hi all
Thanks in advance.
