- 19 Jul 2008
- Lincoln
Hi all,
Trying to set up 5970 + 5870 tri-fire on my UD5 but I'm having some trouble.
My original plan was to keep the 5870 in the top slot with the 5970 in the next slot down so the 5970 had no problem getting air. This wouldn't work, drivers installed, CrossfireX enabled but the 5970 wasn't utilised and idle clocks remained at 3D speeds on all cores.
Swapped the cards around and CrossfireX worked fine however the 5970 got very hot and very loud. Temps were hitting high 90's and the fan was revving its nuts off. This was with both cards at stock clocks.
Is it possible to get the 5870 working as the main card?
More ideally does anyone know where I could get an extra long Crossfire bridge so I can use the 5870 in the 3rd PCIe slot? This would then allow the 5970 to breathe and I can still use my PCI soundcard providing this method would work. (Only bridge I've found was on ebay for over £40 :\)
