10 Dec 2009 at 18:05 #1 Michael.T Michael.T Associate Joined 13 Jun 2008 Posts 125 hi guys i have a N-rated toshiba laptop just bought a 5GHZ N-rated netgear access point are they compatable? dont seem to be gettin a signal ??? cheers
10 Dec 2009 at 20:59 #2 swinnie swinnie Soldato Joined 30 Apr 2007 Posts 3,095 Location Kent Is the access point set to broadcast an SSID?
10 Dec 2009 at 21:29 #3 Michael.T Michael.T Associate OP Joined 13 Jun 2008 Posts 125 yes it is and i cant see it !!!
11 Dec 2009 at 17:47 #4 Firegod Firegod Soldato Joined 12 Sep 2003 Posts 11,543 Location Newcastle, UK You need to have a 5Ghz compatible receiver also. Your laptop is 2.4Ghz. So you'll need something like this:- http://www.overclockers.co.uk/showproduct.php?prodid=NW-141-DL&groupid=46&catid=1452&subcat=1470
11 Dec 2009 at 17:50 #5 ShakenNstirred ShakenNstirred Soldato Joined 5 Jun 2003 Posts 8,732 Location sawley/ long eaton is the netgear only 5ghz my netgear routers 2.4 and 5ghz
11 Dec 2009 at 23:11 #6 Michael.T Michael.T Associate OP Joined 13 Jun 2008 Posts 125 @ ShakenNstirred .... yes i belive the netgear is only 5ghz !!!! @Firegod are all tosh laptops 2.4ghz and would this mean i could not see the signal? could i change the wireless daughter board in my laptop for a dual band ? cheers guys
