Thanks. In that case I suspect that the 14ms refers to the true ISO black to black pixel transition time of the panel (which should indeed take longer than B2B, which suggests that the monitor uses Overdrive).
That's just an educated guess though...frankly I'm surprised to learn that some monitor tech specs still list the honest response time instead of just the nicer sounding marketing nonsense. Props, LG.
P.S., If that didn't make sense, the two different response times refer to different color transitions. Some transitions take longer than others, and G2G, often being one of the fastest transitions, tends to always be listed these days.
Posted from Overclockers.co.uk App for Android
