7 Apr 2007 at 18:23 #1 killsta killsta Soldato Joined 18 Oct 2002 Posts 3,143 Location Around Lo all, My fiancee has a Suzuki Swift and is having some trouble getting it into 5th...will hardly ever go in but it goes in fine if you double declutch it. 5th is the only gear that does it....anybody got any ideas? Cheers
7 Apr 2007 at 18:29 #2 ste_bla ste_bla Soldato Joined 9 Aug 2004 Posts 7,795 Location Milton Keynes Do you have the same problem with reverse?
7 Apr 2007 at 18:45 #3 killsta killsta Soldato OP Joined 18 Oct 2002 Posts 3,143 Location Around Just asked her and she said yes
7 Apr 2007 at 19:03 #4 seth seth Associate Joined 16 May 2006 Posts 276 you should try driving an old corsa, every gear is a challenge
7 Apr 2007 at 19:37 #5 InsomniaCalls InsomniaCalls Soldato Joined 20 Jan 2005 Posts 2,721 Location Whitley Bay Same on my fiesta. Pain in the backside.
7 Apr 2007 at 19:52 #6 ste_bla ste_bla Soldato Joined 9 Aug 2004 Posts 7,795 Location Milton Keynes Something dodgy in the gear box as 5th and reverse run on the same sharft (as do 1+2 and then 3+4). Cant think at the moment what its called though. Although our works van needed the gearbox taken apart to fix it
7 Apr 2007 at 20:49 #7 paradigm paradigm Caporegime Joined 26 Aug 2003 Posts 37,514 Location Leafy Cheshire Probably a synchromesh on the way out.
7 Apr 2007 at 21:23 #8 Firestar_3x Firestar_3x Caporegime Joined 11 Mar 2005 Posts 32,281 Location Leafy Cheshire paradigm said: Probably a synchromesh on the way out. Click to expand... indeedy, syncro on that shaft / gears sounds broken,
7 Apr 2007 at 22:20 #9 killsta killsta Soldato OP Joined 18 Oct 2002 Posts 3,143 Location Around OK cheers for that fellas, will have to get it looked at
7 Apr 2007 at 23:34 #10 KevMarks KevMarks Associate Joined 30 Apr 2004 Posts 233 5th gear problems? Yes I have had that too. I just change the channal there are usualy top gear repeats on UKTV
8 Apr 2007 at 01:01 #11 gareth.e gareth.e Permabanned Joined 9 Oct 2006 Posts 2,819 seth said: you should try driving an old corsa, every gear is a challenge Click to expand... too true... well reverse,1st, 2nd and 5th are all challenging
8 Apr 2007 at 01:09 #12 silversurfer silversurfer Soldato Joined 13 Jul 2004 Posts 20,354 Location Stanley Hotel, Colorado How many miles on this. Maybe check or change the gearbox oil, if little bits of metal pour out then further attention may be required
8 Apr 2007 at 13:42 #13 killsta killsta Soldato OP Joined 18 Oct 2002 Posts 3,143 Location Around It's about 45k. Probably just going to part ex it
