6 CORE PERFORMANCE FOR LESS!
11 Dec 2005
Cheshire
Another epic AMD Bulldozer gaming system! Featuring the AMD FX-6 6100 six core CPU overclocked to an epic 4.00GHz. Enjoy multi tasking power and great graphics performance courtesy of the Radeon HD 7770 1GB GFX card.
"Titan 8250i Sidewinder" AMD Bulldozer FX-6 6100 3.30GHz @ 4.00GHz Six Core System @ £655.94 inc VAT
The "Titan Sidewinder" is one of our best value for money Bulldozer based gaming system. Named after the fearsome snake, strike fear into the hearts of your enemies with the ferocious power that the "Titan Sidewinder" has to offer. Equipped with the custom Sapphire ATI Radeon 7770 1GB graphics card as standard delivering cinematic DX11 graphics and smashing through even the most demanding of games whilst remaining quiet under demanding load. The heart of the system is powered by AMD's 6-Core Bulldozer FX 6100 CPU overclocked to a massive 4.00GHz. With 6 cores you will experience a seamlessly smooth computing experience. A choice of SSDs and Mechanical storage solutions allows you to increase the speed of your system making long loading times a thing of the past and mechanical drive brings in the storage for all your films, important data and photos. Lay waste to anything that stands in your path, with the "Titan Sidewinder".
Why You Should Buy This System
- A guaranteed 4.00GHz performance for the price of 3.30GHz
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
System Specification
- Case: Choose from dropdown options
- Power Supply: OCZ ZS 750 Bronze 80+ Rated PSU
- CPU: AMD Bulldozer FX-6100 3.30GHz overclocked to 4.00GHz
- Motherboard: AMD 990FX (Socket AM3) PCI-Express DDR3 Motherboard
- Cooler: Zalman CNPS14X CPU Cooler
- RAM: Samsung Green 8GB (2x4GB) DDR3 1600MHz C11
- Primary Hard Drive: Choose an SSD or HDD from drop down options
- Secondary Hard Drive: Choose an SSD or HDD from drop down options
- Graphics Card: Sapphire ATI Radeon HD 7770 1024MB GDDR5 PCI-Express Graphics Card (Choose Upgrade options from drop down menu)
- Sound: Onboard HD 7.1 Audio
- Optical Drive: Samsung 24x DVD Optical Drive
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Harness the power of the "Titan Sidewinder" with the AMD Bulldozer and AMD FX 990 Chipset.
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Only £655.94 inc VAT.
ORDER NOW
