6 fans questions
5 Jul 2012
Hey,
Ordering a new build soon, I've opted for the Corsair 460x RGB which comes with 3 x Corsair SP120 RGB fans which I believe are 3 pin, they come with a hub/controller.
With the build I'm also getting the H100 RGB Extreme liquid CPU cooler, it comes with 2 of the same fans and controller/hub too.
You can have 6 fans connected to the hub, but I believe that just covers the lighting.
I was also considering buying a single sp120 rgb to match as a rear exhaust fan if necessary?
How would I connect all 6 of these 3 pin fans to the mobo without a mess of cables? want to keep things neat and the 2 H100 fans would need speed control I guess?
The motherboard I'm getting; https://www.overclockers.co.uk/giga...ocket-am4-ddr4-atx-motherboard-mb-554-gi.html
Thanks!
I go with, 3*120mm for the front(2 of them intake through 240mm CPU radiator) and 1*140mm on the back(exhaust).
