hi guys,
need some help please, my sons pc has 12g of ram which is all ok, the slots are ok as well.
for some reason it only shows 6g for use, it says that windows 10 is using the other 6g to run.
any ideas guys,
12 GB should in practice be plenty for most applications. Windows will relinquish ram it is using if and when a program demands more.
If you want to put more in it depends on what board he has, 12GB sound like a three slot triple setup. Check the maximum size in the manual or online for that motherboard. Check if it is DDR2, DDR3 or DDR4 and what frequency he is running for the ram.
I use Chrome, which is notorious for making use of available RAM and have 40+ tabs open. Because I have so much RAM, Windows is likely also caching C&C3 and BL2.
