6 months of Virgin Media problems - Help
9 Jun 2006
Hi guys,
For 4 months, I was on 30Mbps, but due to apparent over-utilisation in the area, I was getting less than 1Mbps and the connection was unusable. I waited for months for it to be fixed, and after threatening to leave, I was offered to downgrade to 10Mbps which might offer some improvement, which it did, but only mildly. Speed is ok most of the time, still issues with high latency, jitter, and packet loss.
A few weeks ago, I was told the issue in the area was fixed, however it was not the case for me. Several calls later, a UK tech support guy said the likely cause was that I had low downstream SNR. An engineer was sent out, who came today to resolve the issue.
I began to explain the issues with my connection, with the aid of pretty graphs, to which he rudely ignored and began fiddling with the coax cable. He swaps me over to an unused cable attached to the building, and said everything should be fine. I ran a pingtest and said I was still having issues of high latency, to which he says "Don't care about that", before running a speedtest and saying it's all fine. I prompted him about the low downstream SNR, and he just shrugged saying "What can I do?", and carried on to reassure me that it is all fine.
So approaching the 6month mark now, I'm still getting the same problems, and I'm sick of waiting for VM to fix my issue. That is if I can persuade someone that I have an issue, and if I can get them to understand that my issue is to do with packet loss and latency.
I've tried to cancel before, but they always say I've been able to download X amount of data each month, so therefore my connection is fine and I would need to pay a termination fee. As these people are not technically trained, it's impossible to explain to them that my downloads occur outside of peak times, and that my issue is packet loss and latency, not throughput during offpeak times.
Do I have a legal leg to stand on when it comes to breaking out of the contract? My understanding is that I am covered by the sales of goods act (which covers services). The connection is not fit for purpose, and I have given them more than reasonable time to fix the problem. So based on that, I would say they have breached the terms of the contract.
Really appreciate it if someone could offer some advice as to what I can do!
They're a member of CISAS, so they presumably have a formal complaints procedure you could follow.
Ultimately if you aren't happy you could request that CISAS look at the case and make an independent adjudication.
Hopefully they’ll get fed-up with you before then, and either fix the problem, or let you go without penalty.
Get onto the VM forums and Cableforums, plenty of engineers of both boards which have always helped me (which is rarely as i'm one of the luck ones) if i ever had issues with my VM connection.
Yeah I've been posting for months on Virgin Media forums. I've only just discovered cable forums so haven't tried there.
I've got someone high up in the company ensuring that my issue is resolved, so will wait and see :)
Its quite a shame to read your issue with Virgin, I have been with them for since they were Telewest so like 2005 I think and never EVER had an issue... Fantastic download speeds, fantastic customer service with we had issues with our TV signal. The only time its been down in 8 or so years was when there was a power cut in our area... That's it!
Maybe I'm one of the lucky ones but I think Cable is so reliable compared with ADSL.
