Hi,
Just a quick question, also hopefully quite easy for someone to answer:
I just bought a GTX 470 from OCUK the other day, turns out my old clanky power supply only has 1 PCI 6pin Power connector (The GTX470 requires 2), So I'm off out tonight to grab another.
My Question Is, If I have to fill 2 6pin PCI-E power molex sockets on the Gfx card, Can I substitute one for a 6+2 pin ?
Diluted even more my question is, Are 6Pin PCI-E and 6+2Pin PCI-E Power connectors interchangeable?
I have my eye on a OCZ ModXStream 500 or 600w powersupply, and they come with 1x 6pin PCI-E and 1x 6+2pin PCI-E
Thanks in Advance
Chris
Thanks in Advance
Chris
