- 29 Jun 2009
- Cardiff
As the title says I have about £60 to spend on a new graphics card however I currently have the XFX 4850 512mb. Would it be wise to invest in a new card or keep my current one? Thanks
if you can wait 3 weeks untill 29th june, you would be able to get the new card from AMD 450 or 460, the cutdown polais 11 should be at 60-80£ with significant performance boost.
or at least you should see quite the price drop for 2nd hand market when the new line up is released.
I'm in the same boat and waiting for the new releases expected soon to knock down the used prices
A handy site for comparing gpus if like me the numbering means nothing to you
http://gpuboss.com/
Its numbers are meaningless for the most part. Comparing paper specs and synthetic benchmarks rather than actual gaming performance. Anandtech's bench section compares performance in actual games as a better example.Any recommendations on a better one? And what's wrong with that one?
http://gpuboss.com/
