I'm looking to put together a media-and-moderate gaming PC and have about £600 to spend, or a bit more if it'll really make a difference. Raw performance isn't as important as upgradablity and future-proofing, so I'm thinking a good motherboard/CPU and a mid-range graphics card?
So far I'm thinking:
YOUR BASKET
1 x Intel Core i5-2550K 3.40GHz (Sandybridge) Socket LGA1155 Processor - Retail £184.99
1 x Gigabyte Z77X-D3H Intel Z77 (Socket 1155) DDR3 Motherboard £104.99
1 x Sapphire HD 6670 "Ultimate Edition"1024MB GDDR5 PCI-Express Graphics Card £74.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £58.99
1 x Corsair Builder Series CX 600W V2 '80 Plus' Power Supply (CMPSU-600CXUKV2) £52.99
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £39.95
1 x Xigmatek Asgard Pro Gaming Case - Black £34.99
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £17.99
1 x APC Home/Office SurgeArrest 6 outlets with Phone Protection 230V UK (PH6T3-UK) £17.38
Total : £602.26 (includes shipping : £12.50).
It's been a while since I did an own-build - are there any stupid mistakes? Is the Z77 motherboard okay or should I try to stretch the budget to something better? Should I buy a heatsink or can I get away with the intel one?
Luckily I don't need a monitor or an OS, so the whole budget can go into nice shiny not-from-the-dark-ages new hardware
YOUR BASKET
