what difference in games would i notice fps wise would it be worth the extra cash if not overclocking? this is for a friend whos deciding what to build his new pc.it would only be a few fps wouldnt it.he only got a 19 inch monitor aswell.
For games there is absolutely no difference with that graphics card unless your mate is gaming at 1024x768. That is pretty much the only resolution at which the CPU makes any impact.
You can't buy a bad processor nowadays (no, not even Phenom is 'bad') that won't run your mate's games to their fullest extent with that graphics card.
Apologies - I've been looking at benchmarks on Guru3d and FiringSquad... anything above 1024x768 between an FX-62 and a 4GHz Yorkfield was limited to around 15fps difference.
And does it set the card free? Your maximum frame rate is still limited to #73-75fps regardless of CPU speed.
It is nice to see that the minimum frame rate improves in DX9, but I'd be curious to see what the effect of running DX10 would be.
I'm not saying the AMDs are better all-round CPUs - quite simply put, they aren't and get walloped by Core2s. However, if gaming at or above 1280x1024, there isn't that much difference to be had.
It really does'nt matter about the max, it's all about the minimum. COH for example, the minimum with just the card clocked is 21fps which could lead to some stuttering. Overclock the cpu and it goes up to a whopping ...
Sorry to disagree but there is a difference. I game at 1280x1024 and have just rebuilt my rig as it is in my siggy. I have just spent the last week benching this rig with cpu and gpu at stock, cpu at stock with the gpu overclocked to 702/1782/1900, cpu at 3ghz with the gpu at the same overclock and the cpu at 3.6ghz, again with the gpu at the same overclock. What i found was that the cpu does have a large effect on fps in games.
Company of Heroes. Windows XP, DX9, settings completely maxxed out and set to ultra where available.
CPU & GPU @ stock = Min 18 / Max 77 / Avg 73
Cpu @ stock, Gpu @ 702/1782/1900 = Min 21 / Max 76 / Avg 74
Cpu @ 3ghz (8x400), Gpu at 702/1782/1900 = Min 36 / Max 76 / Avg 74.5
Cpu @ 3.6ghz (9x400), Gpu @ 702/1782/1900 = Min 39 / Max 76 / Avg 74.5.
While the avg does'nt really increase look at the min fps. Thats a huge increase. It's clear that the card was held back by the Quad at stock.
World in Conflict. Windows XP, DX9, settings completely maxxed out and set to 4x AA & AF.
CPU & GPU @ stock = Min 20 / Max 86 / Avg 42
Cpu @ stock, Gpu @ 702/1782/1900 = Min 23 / Max 95 / Avg 45
Cpu @ 3ghz (8x400), Gpu at 702/1782/1900 = Min 29 / Max 95 / Avg 51
Same results for 3.6Ghz as 3 Ghz.
Not so big a result here but there is still a decent gain in the minimum and average fps to make a difference.
I ran the Crysis demo but no amount of overclocking on either the Cpu or Gpu made a lot of difference. With everything set to high along with 4x AA and AF i got more or less the same results of Min 17.97 / Max 37.99 / Avg 31.66.
All of the 3DMark benchies also showed huge gains from overclocking the Cpu. I have'nt listed them because they are not games and this is all about gaming. So as you can see, having a powerful CPU really does make a difference and basically sets the card free.
It might be worth metioning that both of the games you tested are RTS which generally do benefit from a faster cpu or quad core.
However the op stated that his friend will mostly be playing FPS games and therefore the cpu difference won't be as (if at all) apparent.
