It's stuck on maximum voltage so any fans you connect to it are max loudness all the time.
The case is pretty heavily modded and I wouldn't want to remove everything just to get a case RMA for a fan controller anyway. Is it worth contacting OCUK or Corsair considering how much the case has been modified
Any idea if you can buy a replacement FC from anywhere?
?Any idea if you can buy a replacement FC from anywhere?
