600T radiator questions
In theory and I say in theory a 200 rad should give you more cooling than a 120.2
120mm x 240mm = 28800mm2
200mm x 200mm = 40000mm2
So better off putting a 200 in the front anyway... ...I think
so would the 120mm on the rear be a complete waste of time? or would it help bring the temps down slightly? and i will be using the Ek hf nickel plexi block for the cpu cleeecooo, just cant use them them on the gpus , as ek dont do one for non reference 6950s.......will start a log when i get all the kit together.......
I reckon it will increase temps as your air isnt going to be exhausting anywhere.. you want your top and front rad to be sucking air in
imo.. go down the 240+200 route now, you can easily add this in if you want it in the future
Well i think ill do the 240/200 as well, can anyone tell me what fittings i should useas I don't have a clue about fittings and tubing and pumps. Fancy nocking me up a basket?
All this was in my basket, so without looking, leyts see if it works!
YOUR BASKET
1 x OcUK Tech Lab - D5 Vario Pump & Alphacool Clear HF D5 Top Value Combo £84.98
1 x EK-CoolStream RAD XTX (360) £79.99
1 x EK HD6970 Full Cover Waterblock - Nickel Plexi **EN Nickel Plating** £74.99
1 x EK Supreme HF CPU Waterblock - Nickel Plexi £56.99
1 x EK Dual Bay Spin Reservoir - Acetal £46.99
1 x XSPC EX240 120mm Radiator - Black £39.98
1 x Lamptron FC5 V2 5.25" Bay Fan Controller - Black £34.99
5 x Scythe Gentle Typhoon 120mm 1850 RPM - 3 Pin £15.98 (£79.90)
1 x Mayhems Aurora - Galaxy Purple Coolant 1L £14.99
1 x Masterkleer Hose Pack PVC 15,9/11mm (7/16ID) Clear 3.3m £10.88
14 x OcUK 1/2" Barbed Fitting G1/4 - FatBoy Style - Black Nickel Finish £1.68 (£23.52)
Total : £560.83 (includes shipping : £10.50).
EDIT:
Not too bad :D
I'll knock you up a specific one :)
I think that rad is too thick mate :( when i whip out the tape measure there is about 36mm of space between the grill and top of the board. :O £500 jesus! Was not expecting that! Love that mayhems stuff, the blue is crease!
Think I will go for the xspc dual rad, 35.5mm thick, i found another build log that has that rad in the top :) cheers for that, muchly appreciated.
Yep, what do you say to that? yay or nay? i'm looking at the corsair 600t white water cooled build (complete) if you catch my drift (not sure if linky is ok)
Hardware Labs Black Ice® SR Series 240mm Dual Radiator
54mm
fits in the top of the 650D.. is the 600T that different?
A bit it seems, you have the rad, grill that you mount the rad too, fans, top mesh that removes. kinda odd. I was thinking the Hardware Labs Black ICE GT Stealth 240 Radiator, 30mm thick. but the build i was hinting at the guy is using the xspc one, so i might go for that if it is in stock. Still not 100% sure if i will yet as she wil be rather costly to cool. My kuhler 620 is taking care of business and i can live the the F15 that is my reference 6970.
