600T Window Panel Fans
Been looking at that window side panel myself, looks good if only for the extra fan's.
I'm sure there is 4 connectors for the fan controller, but i'm not sure if it will take 4 extra fan's.
Another option I'm looking at is buying a 230mm fan and installing that at low rpm (900) on the side instead. (Easy enough to create a fitting solution for it using thin aclylic and connecting to 4 corner boltholes) round about 130 CFM and low noise.
Failing that anyone know of a 240mm fan on the market (Have looked, can't find)
Plan is to have
Front-200mm Intake, Side-230mm Intake, Top-200mm Exhaust,
2x570 Graphics Reference design - Exhaust back, 1x H70 Hydro-Exhaust (Push/Pull) back,
Should create a positive Pressire.... by math.
I'd recommend the clear tri-cool fans :) I've just put a clear (but 230mm and lit) fan in the mesh panel of my 932 and it looks better than the black fan as you can (to a point) see through to the components :)
the tri-cools on low would provide a nice intake and they're near-silent at that speed!!
Though those fractals do look nice :)
I will see what my temps are with my new 600T when I finish the build.
I've replaced the front standard fan with a 180mm Silverstone Air Penetrator. Also the top fan with 2x 120mm Scythe Kaze 1900RPM. The rear with a 38mm Scythe Ultra 3000RPM fan.
I needed to drill some new holes in the fan so I could use the standard case mountings. Also the new front fan is too wide to utilise the HDD mounting at the front. I'll probably use a 5.25" adapter to mount my HDD.
What sort of temp decreases are you seeing with this side fan setup?
The 600T fan controller can handle 6 watts per channel. (12v)
So you can have 0.5A per channel.
Am I right in saying the one channel could run 4x Fractal Design 120mm fans?
0.72watts each x4 = 2.88watts total.
