600w/700w for this system?
25 Oct 2009
Caerphilly
One final hurdle is Power! Im not too sure if 600w would be enough to accomodate this setup;
- i5 750
- Gigabyte GA-P55-UD3
- Ripjaw 4gb (2x 2gb)
- Corsair H50 Water CPU Cooler
- Asus Radeon 5850
I'm looking at the OCZ StealthXStream range; 700w.
Would 600w be enough for this system (with the possibilty of more coolers/fans/fan controller at a later date) ? Or should I go with the 700w version?
Thanks, Rhys
The BeQuiet Striaght Power Pro 650W was around that price. Still is on some sites...
Can't find it anywhere for that price :(
Showboat said:
Antec premium 650w is much cheaper here on ocuk than other competitors, and it's their top line product.
It comes with the 2 6pin pci-e connectors you need.
Thank you Showboat.
A good looking PSU, does it really warrant spending the £90 on a 650w psu?
My main concern is is there enough power for future upgrade's? More cooling mainly...
Thanks for all the help!
CF?
I've just realised that I need 2x 6pin PCI-E power connections for the Radeon 5850... The OCZ only has 1x6pin and 1x8pin.. Shoot..
(Am I right?)
What else could I be looking at? :confused: :rolleyes:
On that psu the 8 pin splits off to make another 6 pin. I have this psu and need 2 6 pins for a 4870.
I can highly recommend this psu as i haven't had any probs and its supported by a great warranty.
Excellent! Thanks Sindri... That's what I was after. Cheers! ;)
