I bought a Dell poweredge server and it is NOISY.
it has 7 60 mm fans in total, 2 rear exhaust fans
•Fan Size: 60 x 60 x 38 mm
•Motor Type: DC Brushless
•Air Flow: 50.2 CFM
and the other 5 are as follows
•Fan Speed: 6800 RPM
•Air Flow: 38.35 CFM
•Noise Level: 46.5 dBA
•Fan Dimensions: 60 x 60 x 25 mm
The 2 rear fans are definitely noiser.
I want to replace them all with something that isn't quite so noisy.
They absolutely HAVE to be 3 pin as well, the server monitors fan speed and as soon as one fan is unplugged it speeds up the 2 rear fans and as these are Delta "screamers" you can imagine the noise.
I want to keep the airflow as high as possible and I am not looking for a silent solution just a noise reduction overall.
If I can use other fans rather than deltas that would also be good as they are very whiney fans and the noise is quite annoying.
The server will be stored in a cupboard so a lot of the noise is negated but it is still noisy enough to be heard outside that room.
Thanks
James
[EDIT]
Think I have found the spec of the 2 rear fans
•Fan Type: 60mm Axial Fan
•Rotation Speed: 8000 rpm
•Noise Level: 54.5dBA
•Airflow: 50.15 CFM
They are Delta EHE which explains why they are so damn loud
•Air Flow: 50.2 CFM
Thanks
James
[EDIT]
•Airflow: 50.15 CFM
