Man of Honour
- 17 Oct 2002
- Retired Don
Hi guys. We've just fitted a new light fitting to our bathroom. Its a very simple round fitting, with a brushed metal rim and glass bottom. It says 60W bulb maximum.
How stringently does this need to be followed? It is all metal and glass, but the bulb is not out in the open so lack of heat dissipation there i guess, and is also fixed directly to ceiling, so the bulb is about 10mm away from the ceiling seperated by the metal casing of the light fitting.
Cheers guys,
Mal
Cheers guys,
Mal
