£630ish build help
5 Jan 2004
its going be gaming for and some encoding for a friend whose going up from a q6600:
MSI GeForce GTX 460 Cyclone 1024MB GDDR5 PCI-Express Graphics Card £152.74
Intel Core i5 650 3.20GHz (Clarkdale) (Socket LGA1156) - Retail £135.00 Asus P7P55D-E Intel P55 (Socket 1156) DDR3 Motherboard £98.98
Antec TruePower New Modular 650W Power Supply £69.99 OCZ Gold 4GB (2x2GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (OCZ3G1600LV4GK) £59.98
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £40.98
Coolermaster Elite 335 Case - Black £32.99
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1156/LGA1366) £30.98
Sony Optiarc AD-5260S 24x DVD±RW SATA ReWriter (Black) - OEM £12.91
Total : £634.57
No os needed, anyone fine tune it?
*btw he will O/C to at least 4.00ghz
Your basketProduct Name Qty Price Line Total
Gigabyte GeForce GTX 460 OC 1024MB GDDR5 PCI-Express Graphics Card £151.99
(£129.35) £151.99
(£129.35)
Intel Core i5 760 2.80GHz (Lynnfield) (Socket LGA1156) - Retail £144.98
(£123.39) £144.98
(£123.39)
MSI P55A-G55 Intel P55 (Socket 1156) DDR3 Motherboard £89.99
(£76.59) £89.99
(£76.59)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £65.99
(£56.16) £65.99
(£56.16)
Coolermaster Elite 430 Windowed Case - Black (with 500w Elite Power PSU) £62.99
(£53.61) £62.99
(£53.61)
(£34.88) £40.98
(£34.88)
Akasa AK-CCX-4002HP Venom CPU Cooler (Socket LGA775/LGA1156/LGA1366/AM2/AM3) £34.98
(£29.77) £34.98
(£29.77)
(£10.99) £12.91
(£10.99)
Sub Total : £514.74
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 17.50% VAT : £91.92
Total : £617.16
the i5 760 is a true quad core, what you had is just a dual core with hyperthreading.
So you know, the i5 you've specced is a dual-core. If you wanted a quad core you would need the i5 760.
Good call by burrell there, the mobo he is referring to is:
http://www.overclockers.co.uk/showproduct.php?prodid=MB-124-MS
That RAM is horrible stuff, so many bad reviews and issues, I'd swap it out for this:
http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS
Finally, that PSU is overkill and costing you money better spend on the above ;) - I would get this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-033-CS&groupid=701&catid=123&subcat=1084
cheers for your help, the question is for the motherboard is the GD65 better for with the free 3.0 card and sli or the G55 with only crossfire but has built in usb 3.0 and sata 3. I'm leaning towards the first due to mate wants nvidia because he wants to try 3d sometime later on.
,thxs
hmm i'll see if he can up the budget by 30ish quid and get the ud4. If he does hopefully (minus gfx card update), this system should be ok for 2+ years for him.
,thxs
