64 & 32bit
I thought that when you purchased windows 7 you got BOTH 32 and 64bit versions on the same disk so you could chose???
My 7 Home Premium came with two discs - one labelled 32bit software and one labelled 64bit software.
Its an upgrade, although it seems if you want to upgrade from xp, or various other versions then it does a full custom install anyway from scratch....so essentially retail.
For the student offer you have to specify if you want 32 or 64 bit so I assume it's either one or the other and not both.
Oh, shame as my netbook is only 32bit but if i wanted to use it on my desktop instead then i woulduse 64bit!!!!
Ho hum, canna really grizzle at £30 :)
